Message 11 of 13
Re: YouView Humax DTR T2100 will no longer record anything
I believe the recording schedule  that you see is only part of the the picture. There are potentially many series  recordings that have been set and are not showing  as no new episode  of the series  exists in the schedule of upcoming  programmes. Those historic  series  recording only lapse after x weeks/months (x defined by Youview).
Message 12 of 13
Historically it's been the case that if a box stops recording then it's been down to the index structure on the disk being corrupt which only a full reset , wiping all existing recordings , will fix.
Message 13 of 13
I'm in the same boat as don't want to lose some existing recordings. Like you I also lost all scheduled recordings from the planner. It appears from all the comments a full reset is the only way to recover the record function. Thanks
Tags (1)
