Message 11 of 35
Re: Youtube on pro box
You tube hasn't arrived on my BT pro box .
Software: 4.1.130
Message 12 of 35
Still not on mine either.
Message 13 of 35
It was mentioned on the forum everyone would have you tube by 10th July
Message 14 of 35
Everyone will have the new menu by the 10th. YouTube will be made available when we receive certification from Google.
Message 15 of 35
I appear to have old software as mentioned in my previous post
Message 16 of 35
I assume you've checked for updates? On that screen, where there are buttons on the right hand side, is there anything below where it says "Update apps"? e.g. any mention of "Feedback group"?
Message 17 of 35
Just says cannot update your apps
Message 18 of 35
Ignore the Update Apps button itself - it does nothing (the Update Software button is the only one that does anything). Is there anything shown beneath the button though? Or just blank space?
Message 19 of 35
Just blank space Darren
Message 20 of 35
Under apps tab , I have feedback group yvurbtboxpro
