Message 1 of 14
annoying popping/ clicking noise from Youview box
Hello , i have  a Youview box connected to my LG TV which is then connect to a soundbar, in both cases via HDMI. The issue only concerns the Apps  in the Youview box. When I  play one of those, I get the noises at the commencement of each programme, at the the start of each add on the commercial channels and between them , therefore because of those add breaks  the likes of   itvX are more annoying than on Netflix or iPlayer.
The problem does not arise with mainstream channels or with the Apps on the TV itself . Does anyone have any suggestions? Thanks
13 REPLIES 13
Message 2 of 14
Re: annoying popping/ clicking noise from Youview box
I forgot to add that TNT sport is unwatchable due to frequent juddering and pixelation. I normally rely on Discovery + app on my TV. It's not ideal,though, because I also like to record sporting events and that is quite impossible
Message 3 of 14
Good afternoon @donmaico
Welcome to the BT Community Forums!
Has this been the case for as long as you've used your TV Box with this sound bar, or did the sound issues develop over time?
Have you had a chance to try swapping out a different HDMI cable to see if the problem persists with different cables too?
Peter
Message 4 of 14
TNT Sport juddering and pixilating on the TV box itself and not the app would related towards the quality of connection your box is getting from your router. Could potentially point to a wider issue with your connection but you'll need to rule out anything internally, like is the YouView box connected via ethernet, and if not does it improve things?
Is the clicking and popping come from the box itself or the speakers?
EE900 | Nokia ONT | Ubiquiti ER-X | EETV Box Pro (IP Mode) | Unifi CK2 | 6x Unifi U6+ | 4x Unifi SAK Ultra
Message 5 of 14
the sound comes via the soundbar but as said no other source produces it
Message 6 of 14
i would say it has developed over time. I'll change the cable and see if I get better results, thanks
Message 7 of 14
Thanks @donmaico!
Please keep us posted on how you get on.
Peter
Message 8 of 14
will do
Message 9 of 14
Are you using surround mode for audio on the youview box?
Message 10 of 14
no i had it on stereo. I have changed it to surround to see if that makes a difference
