Message 1 of 2
bt eetv box
hello my eetv box has stopped getting signal for tv channels don,t have an aerial goes through wifi. wifi is fine.
can use the apps eg itvx player bbc iplayer now etc fine but the actual tv channels not getting signal worked fine for the last year then went off 2 days ago,
have done the usual wifi signal is strong, have factory reset it still not getting signal,
1 REPLY 1
Message 2 of 2
Re: bt eetv box
@speedy09 Are you getting an error message when you try to watch the channels?
