Message 1 of 2
bt pro box , how do i remove old log on info from discovery+ app
1 REPLY 1
Message 2 of 2
Re: bt pro box , how do i remove old log on info from discovery+ app
Not sure of precisely what are looking to do . If you are looking to sign out of the app then
If you are already  (signed in as a user ) in the discovery+ app  on the Box Pro then the left hand side menu  is I believe (Home/Sports/Shows/My List/Search/Account). Select Account and there is an option to Sign Out.
