Message 1 of 3
bt tv pro box
Am I right in thinking that with my bt pro tv box, with an internet connection I can only record one channel and watch one other channel, and also now cannot fast forward through advert breaks with ITV.  However if I connect through an aerial, I can record up to four channels and fast forward through advert breaks on ITV
2 REPLIES 2
Message 2 of 3
Re: bt tv pro box
Hi @sparklingwater
That is correct.
Message 3 of 3
Re: bt tv pro box
@sparklingwater
And you will get all of the broadcast channels on Freeview, instead of the subset offered with IP.
Unless, that is, your local transmitter is a Freeview Lite one, which may tip the scales back towards equivalence with IP.
*** Longtime YouView box owner, Broadband customer (was BT, now EE), finally an EE TV subscriber ***
