Message 1 of 2
ee remote vs bt remote
i have just moved from BT to EE and have new EE box and the EE remote
my question is how do you quickly get to the categories list now
on the old bt remote you would push the blue button and you would be able to scroll through categories, films, documentaries etc
on the ee remote i cant work out how to do it ?
it is frustrating as it seems you need to scroll back upto the top to access the menu
is this the only way ?
thanks
1 REPLY 1
Message 2 of 2
Re: ee remote vs bt remote
Hi @londonman
Thanks for coming to the community.
The EE TV box is a little different with one extra step.
If you press the Guide button, you'll be taken to the main TV guide, then if you press the blue button on the remote,  you'll see the categories highlighted at the top of the guide and can scroll left and right to choose.
If you then press the blue button again, you can choose all channels again.
Michael
