Message 1 of 5
eero pro
Hi just purchased a eero pro system but the bt tv pro box is saying problems with broadband connection but everything thing else is working. All smart tv functions working both wired and wifi will not work saying it is connected but no picture
4 REPLIES 4
Message 2 of 5
Re: eero pro
If you're trying to use it for IP terrestrial TV and NowTV etc, Google suggests that the eero system doesn't support Multicast/IGMP...so that aspect won't work. If the Pro Box is in aerial mode, it should still connect and you should be able to use the Pro Box apps for streaming
Message 3 of 5
Re: eero pro
This question was asked a couple of years ago on the eero community website and the answer then was NO, eero does not support Multicast/IGMP
implementation of IGMPv3 (Multicast) for IP TV - Feature Requests - eero Community
Message 4 of 5
Re: eero pro
I have no aerial connected haven’t used it for a long time so if connect it everything should be ok. I had bt wholehome discs before the tv worked fine but everything else kept losing connection
Message 5 of 5
Re: eero pro
Cheers
