Message 1 of 2
faulty tv box
Have done everything,    software updates, factory reset,   diagnostic tested by  customer services on live chat.
Broadband connection is excellent.      However picture signal quality completely pixilates.   Then it seems ok.  But then pixilates once again.
there is a hard drive failure i suspect.
So, another call to Bt I suppose...
1 REPLY 1
Message 2 of 2
Re: faulty tv box
is it a similar problem and the same TV box Pro that you experienced in Dec2022  ?
discussed in thread
https://community.bt.com/t5/EE-TV-YouView/slow-box/m-p/2270271#M70127
How is your box currently connected  ?
