Message 11 of 34
Re: now tv channels not working
I’ve been watching the cricket on the app on our Pro tv box too. Hopefully the problem will be resolved quickly, but it would be interesting to know if the problem is with BT or NOW/Sky,  given that the app feed is working.
Message 12 of 34
& me
Message 13 of 34
Yes mine don’t work either I called them and thier no about the issue
Message 14 of 34
There's an issue with the NowTV feed that is supplied using multicast, it's been reported and will be fixed as soon as possible.
You have all the same content available through the app, if you login to the NowTV app on the Youview box, the content works.
For other supported devices look at https://help.nowtv.com/article/what-devices-can-i-use-to-watch-now
Message 15 of 34
Me too. None of my VIP channels are working, just a message saying
there is a transmission problem. Tried the online technical help chat
but after half an hour no help available, very busy!!!
Message 16 of 34
Ditto! Grrr!!!
Anonymous
Not applicable
Message 17 of 34
The BT Status page and post in this forum have been updated: BT TV Status
Next update at 7.30 PM, the cricket has just finished. 😁
Message 18 of 34
I have BT Entertainment and the channels are working now
Message 19 of 34
Yes,mine too and now that it is Stumps,sky cricket is back on!!!
Message 20 of 34
