Message 11 of 24
Re: problem recording some channels
I've been searching the house for one as I figured all it was looking for was a connection of some kind and I don't.  We had SKY previously and the antenna cables from the disk have a threaded barrel on them so won't push into the connector on the back of the BT TV box (It's the Pro one by the way).
Anonymous
Not applicable
Message 12 of 24
I don’t have a Pro Box to test, but according to YouView themselves you can use all of their boxes without an aerial, so forcing you to connect one just to setup seems daft.
Is there no on screen option to skip tuning aerial based channels?
Message 13 of 24
There is no option just that one button and it won't go any further.  I remember someone else on the forum telling me that you cannot complete setup without an antenna connected initially but once it's completed it doesn't care if you have an antenna if you just watch subscription channels.
Anonymous
Not applicable
Message 14 of 24
Time to order the cheapest portable aerial you can find I’m afraid, unless a friendly neighbour can help?
Message 15 of 24
Does it have to be an antenna or can u fool it by just plugging a cable in?  I have found a short cable that fits.
Message 16 of 24
All my neighbours have SKY unfortunately
Anonymous
Not applicable
Message 17 of 24
I don’t know if this will work, but it is what I was suggesting. Worth a try.
Message 18 of 24
Have tried clicking OK on the remote with the antenna cable connected but no joy unfortunately.   I'm guessing it's just OK you press as I don't remember from when we did the original setup of the box.
Surely it's just looking for something in the antenna IN port and doesn't care if it's an actual antenna?!
Anonymous
Not applicable
Message 19 of 24
That is what I was hoping.
Sorry, I don’t know what else to suggest at this stage.
Message 20 of 24
Thanks for your help.  Looks like Iam left with taking it into work Tomorrow
