Message 1 of 3
purchasing a film on BT TV
Hi folks
The wife is a big Downton Abbey fan and she mentioned that the latest Downton Abbey film is available on BT TV for £15.99.
If I purchase it how long will she have access to it for and do you have to start watching it within a pre determined time?
Cheers
2 REPLIES 2
Message 2 of 3
Re: purchasing a film on BT TV
@WelshDave
I  can see  Downton Abbey A New Era 2022 as Buy for £13.99  HD. On my BT TV Player., so it may have reduced in price.
note that HD and SD versions are considered separate items so make sure you order the right one.
If if is a Buy  item it can be watched as many times as you want for an indefinite period so long as you have a BT Tv subscription. ( If you cease your BT TV subscription there is the ability to watch (in SD format I believe) via   BT Tv app on some devices.  BT TV terms and conditions has section(s) on Buy to Keep content ).
Some items are offered as Buy from  and/or Rent From .
If it is a Rented item you have 48 hours from when you Rent it to watch it as you wish on your box.
Message 3 of 3
That's great!
Many thanks for replying.
Best Wishes
Dave
