Message 1 of 4
scheduled recording(s) gone
All preexisting scheduled recordings have gone. Setting up a new one results in nothing happening when the red R button is pressed. Handset works fine.
The box tells me it is a Humax DTRT2100.
This page purportedly lists all supported boxes:
https://support.youview.com/youview-box/box-and-remote/using-maintenance-mode/
It only shows a '2000' model of a somewhat similar name.
Is this  just website laziness or are we supposed to 'just know' ?
Either way am blocked in trying to proceed/schedule recordings.
Yes box was powered off and left a while before restarting.
Box tells the software is uptodate when I asked it to do an update.
What now ?
3 REPLIES 3
Message 2 of 4
Re: scheduled recording(s) gone
Hi  @steveoxfD
YOUVIEW withdrew from direct customer facing support and now direct all support to the box manufacturers ,
The 2000 was a Humax retail model. Youview still display support documentation for that model.
The DTR 2100 model was a box made by Humax for BT so Youview direct you to BT.
The relevant support pages for the BT models which describe how to do reset are at.
https://www.bt.com/help/tv/fix-a-problem/tv-boxes/how-do-i-reset-my-bt-tv-box-
Are you able to play your old recordings  ?
If so try a maintenance mode reset  keeping recordings first. Instructions appear if you select your box image on that webpage.
This may resolve your problem but it is more likely only a full reset deleting recordings will resolve.
Logic here is that a problem with you scheduling recordings may not be cleared by a maintenance mode reset that preserves recordings.
Message 3 of 4
Many thanks !
Did the 'Keep Recordings' reset.
Your logic was correct, scheduled recordings still nbg.
Swnbo has to go through to see what will be lost that she would like to save/recreate after we invoke the nuclear reset.
Will post back when we cross that bridge
Message 4 of 4
Crossed that bridge.
Function restored, tedious to re-establish the recordings but that is the nature of the beast.
Many thanks.
