Message 1 of 8
slow box
Just BT Tv,   the picture pixilates a lot and the box is very slow changing channels or won't change at all.   What am I supposed to do?
I've streamed tv before and never had such problems?   The internet is a good speed .
7 REPLIES 7
Message 2 of 8
Re: slow box
Which box do you have, the old DTRT-2110 series seem to have become very slow
Message 3 of 8
Re: slow box
its a new one RTIW387, and the picture pixilates a lot. I think the box is faulty.
Message 4 of 8
Re: slow box
If you haven't already, try factory resetting (not just rebooting) the box before you condemn it.
How do I reset my BT TV box? | BT Help
Message 5 of 8
Re: slow box
I only got it 3 weeks ago,    btw how much pixilation is acceptable ?   thanks
Message 6 of 8
Re: slow box
You may have only just got it but it's still worth trying, if you check this forum you'll find cases where people have reset brand new gear to resolve a fault. Give it a go -you've nothing to lose.
As to how much pixilation is acceptable, there's so many variables that it's not a straight forward answer, your connection speed, the connection method from your box to your hub (ethernet cable, wi-fi, mini converter etc) can all cause problems.
Are you seeing any error messages
Message 7 of 8
Re: slow box
thanks for your response,  i've just done the first method of resetting the box,  will follow this up
best
Message 8 of 8
Re: slow box
after all that it was simply moving a wi fi disk   closer to the box that has fixed it.
