Message 1 of 5
teletext on youview
When listening to BBC radio on  Youview I no longer can view teletext content.  The banner page does not appear so the red button is not operational. How can this be fixed please?
4 REPLIES 4
Message 2 of 5
Re: teletext on youview
Hi  @jamboni  Which Youview box are you using and if the BT Box Pro are you in aerial or iinternet mode ?
Message 3 of 5
Humax DTRT4000
Message 4 of 5
Thanks for @jamboni  clarifying the box as T4000, Unfortunately  I don’t have that box currently connected to view so will have to on some other forum members to answer.
Message 5 of 5
I just rebooted the BT box and lo and behold the teletext reappeared. Happy now I have found a workaround in case of future occurrences. Having this board to turn to at least got me thinking.
