Do you mean
Guru
0
Another Addition to the Freeview channels - 61 true Entertainment
From 6am Tues 6th August True Entertainment starts broadcasting on Freeview
God new for Little House on the Prairie and The Waltons fans.
Distinguished Guru
0
Re: Another Addition to the Freeview channels - 61 true Entertainment
What's the source?
Mind you it is an awful channel
BTLife | 1967 Plus Radio | 1000 Classical Hits
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Helpful Post?
If a post has been helpful, say thanks by clicking the ratings star.
Guru
0
It is brooadcasting that launch message on ch 61 which I tuned into by chance because it is the channel next to BT sport 2.
Subsequentlly I found  is a brief mention at
http://www.a516digital.com/
Distinguished Guru
0
I see it on my YouView box but showing just a frozen picture
Helpful Post?
Guru
0
[ Edited ]
Yes I just checked a Vision & Youview box ... the vision is showing a message whereas the Youview  has a frozen picture. same transmitter so I guess may be down to how/when the different boxes were last scanned for channels.
Distinguished Guru
0
Did a rescan and that solved the frozen picture, I wonder what the hours are going to be?
Helpful Post?
Guru
0
Looks like 6am to 3am with maybe teleshopping in the remaining 3 hours.
first days schedule is now showing at
http://www.a516digital.com/2013/08/true-entertainment-launches-on-freeview.html
Guru
0
[ Edited ]
The article  also explains that the channel is not available on Freeview in Wales.
0
Not on my Freeview (from the Wrekin transmitter) .. not that I'm terribly bothered anyway now I know what is on it
Guru
0
[ Edited ]
Lucky beggar! Unfortunately mine moves and I can hear it.
