Do you mean
0
Accepted Solution
Audio Description / Subtitles turning itself on
Hi,
On a few occasions, Audio Description and Subtitles have turned themselves on halfway through watching a programme.  It has always been after we had paused the recording and then hit play again.
Has anyone else had this problem?
Is there a shortcut button on the remote I might be pushing by accident?
Cheers
Guru
Re: Audio Description / Subtitles turning itself on
IF on the new llook system
  1. Temporary switch: Press the # button on your remote control to toggle subtitles on or off and the * button to toggle audio description on or off. This setting will be lost when your BT Vision+ box is put into standby or switched off.
Distinguished Guru
[ Edited ]
Tonto81 wrote:
Hi,
Cheers
PossiblySmiley Wink
* turns audio description on and off
# turns subtitles on and off
edit. zulu's reply wasn't there when I read it.
-+-No longer a forum member-+-
0
thanks to both of you :-)
0
On the latest remote those options * & # do not appear. It appears that the only way to switch off this annoying problem is by using the "Sub" button bottom right on the new remote.
Distinguished Guru
0
[ Edited ]
That annoying problem is actually an essential tool for many people with hearing or sight disability. Just make sure you don't turn it on in the first place and be happy.
You can click the white star next to this message if you think it was helpful.
