Do you mean
Newbie
BT VISION VOLUME
The volume on BT Vision is extremely poor when watching any standard freeview chanels however if I watch on demand it gets even worse and when I switch over to watch any chanel directly on the digital TV the volume is excellent.
I have the silver BT vision box connected to the TV via scart and the signal come directly into the vision box then up to the TV.
Any suggestions on how to fix this problem.
Guru
Re: BT VISION VOLUME
Has it always been like this, or has this only recently started happening?
Does your TV have the ability to offset the volume on different inputs? If so that the SCART input isn't set low.
Make sure the SCART cable if fully pushed home at both ends.
