Do you mean
0
Accepted Solution
BT Vision Box Upgrade.
I am in the process of upgrading my BT Vision box from the silver one to the all new all dancing black one. Can anyone tell me if my existing ESPN viewing card will be compatible with the new box. Thanx.
Re: BT Vision Box Upgrade.
I cannot think of any reason why your card will not work with the new box, you should be able to just plug it in and that should be it.
David
0
Thanks for your reply Snoopius, probably concerned about nothing .
Expert
0
No difference at all between the two apart from the power.
0
Yea its all good. My ESPN card works fine int the back box Smiley Very Happy
Expert
This box operates exactlly the same as your silver box. And your card will work in the box.
The only new fetures are the box uses less power, the remote you have to hold mode in when you attempt a remote function.
The menus are Identical to your new box and this offers in advancements you will notice no difference with this box whatsoever. This box does everything your old box did. This box does nothing extra.
I have owned both boxes and know. Did you pay outright for this box?
0
No got it at a bargain price of 37 notes and its brand spankin. Thanks for ur reply !
