Do you mean
Newbie
0
BT Vision Box clicking and resetting
Hi I hope I can get some advice, my vision box is consistently clicking and partially resetting itself I have seen the same issue mentioned within a number of support sites generally pointing towards a BT upgrade to solve the problem, it's getting to the point now where I'm seriously considering switching to another provider. the hub and phone conection are in a seperate room from the TV so hard wiring isn't really an option. Any advice would be appreciated.
Moderator
0
Re: BT Vision Box clicking and resetting
Hi ianm489,
I'm sorry to read about the problems with your vision box. Can you try these BT Vision help checks and let me know if they help?
Cheers
Neil
NeilO | BT.com Help Site | BT Service Status
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Try a Search
See if someone in the community had the same problem and how they got it resolved.
Make sure you are logged into the forum otherwise you will not see our contact link when a moderator offers help. When sending us your details please don’t send a Private message (PM), we can’t deal with account/service issues via PM so please use the contact link. Thank You
Order tracker survey We would really appreciate it if you would take a few minutes to complete a survey about BT’s order tracker? You can access the survey from this link Order Tracker Survey
