Do you mean
0
BT Vision - Factory reset implications
Can anyone advise me about the implications / consequences of a factory reset?  This is something BT have advised me to do in order to sort out the problems I'm having with the recent upgrade.
I realise that I will lose my recordings and series settings.  I had the BT Vision box delivered in August 2010, so I suspect everything will roll back to around that date.  In particular will it reinstall the 'old' software?  If so will I be in a position to stop it from installing the new upgrade, the thing I'm having problems with?
What else might happen?
