Do you mean
Community Manager - Retired
BT Vision Troubleshooting
[ Edited ]
We have lots of troubleshooting advice to help you if you have issues with BT Vision.
Help with technical issues and problem-solving tips for Vision and the Vision+ box
Have you got an error code on–screen?
Find out the meaning and steps you need to take to solve the issues they relate to.
Retired BTCare Community Manager - StephanieG and SeanD are your new Community Managers
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on the left-hand side of the post.
