Do you mean
0
BT Vision + box problems
I have a BT Vision+ box and infinity broadband and I have been having problems with my Vision+ box freezing or resetting, in some cases i have set the box to record a program only to find a ''!'' symbol in red is displayed with '' failed to record'' prompt. This is becoming very frustrating, i am having to switch of the box by pressing the on/off button on the front of the Vision+ box.
Can anyone help out there?
Regards
N.Dowdeswell
Guru
0
Re: BT Vision + box problems
I agree it is terribly frustrating. Unfortunately you I assume are on the new software and these are know bugs have shown up. Until there is another firmware upgrade then we are stuck with it. Smiley Sad
BTLife | 1967 Plus Radio | 1000 Classical Hits
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Helpful Post?
If a post has been helpful, say thanks by clicking the ratings star.
0
AND: Still have to pay for it unfortunately.
Recognised Expert
0
[ Edited ]
If it doesn't work, Oh No you don't.
Rank - Mostly Harmless.
0
Is it really, really "simple" to get a refund from BT, Look throughout all the forums here and tell me most are "satsified" or "not"
Recognised Expert
0
Yes, it really, really, is.
And this is a problem and help forum. So what did you expect? Roses?
0
  • Like you I have been having the same problems with the new black BT vision box since August. I have lost count of the number of times I've spoken with India about the problem always being told that it is a software problem which they are sorting out.
  • Yesterday I finally got to speak to a tech guy who said the same thing, they have been having software problems, starting with 10 which they have now narrowed down to 3
  • Once again they updated my box but still it freezes and is actually worse now because every time I try to get BBC i Player it restarts itself, one of about half a dozen time a day.
  • BT ARE A DISGRACE, THEY SHOULD HAVE SORTED THESE PROBLEMS OUT BEFORE MAKING US GET RID OF THE SILVER BOX, WHICH NEVER GAVE US ANY PROBLEMS IN FAVOUR OF THIS USELESS BLACK BOX.
  • I will continue to ring them every other day just to get under their skin until this problem is sorted.
Guru
0
[ Edited ]
Except you're not getting under their skin, you're getting under the skin of anyone who's behind you in the queue. You know you're not going to get a fix when you ring and you're not going to speed anything up by doing so, so why put yourself and anyone who actually needs help from the helpline through it?
