Do you mean
Newbie
0
Accepted Solution
BT Vision connection to Broadband
I don't have BT Vision as yet. If I get it, do I need a cable to connect from the BT Vision box to the Broadband hub? Will it connect wirelessly?
If I need a cable do BT expect me to have a cable ready when the engineer comes, or will the engineer drill through floors/walls?
Expert
0
Re: BT Vision connection to Broadband
Your box will come with Powerline adapters that plug in by your hub and by your telly; they use your internal wiring rather than wi-fi but it is 'wireless' in the sense that you can't see the wires Smiley Wink
Newbie
0
Great thanks.
Does that mean you can run another TV in another room from BT vision too?
Recognised Expert
0
JDexter wrote:
Great thanks.
Only with a video sender.
And Re; your original question,here's the set up guide -
http://www.productsandservices.bt.com/consumer/consumerProducts/pdf/entertainment/BT_Vision_selfinst...
Cheers,
Del.
