Do you mean
Newbie
0
Accepted Solution
BT Vision remote reset
How do I reset the remote so when I turn on the Vision box it doesn't turn off the TV? Thanks.
Guru
Re: BT Vision remote reset
Do you see the bottom button on the left hand side MODE.
Press it once and you will see the BT Vision button at the top turn blue.
If it flashes once it is in TV control mode.
If it flashes several times it is BT Vision control mode.
Just press it till it flashes in to  the mode you want.
BTLife | 1967 Plus Radio | 1000 Classical Hits
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Helpful Post?
If a post has been helpful, say thanks by clicking the ratings star.
Distinguished Guru
To set the remote up to work with your television check this link out Here It explains how to programme the handset
(If I have helped you in any way to say "Thank You" please click on the star next to the message. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
On the black remote you have to hold down the mode and the off together on mine for it to switch off the TV
Newbie
0
Thankyou - using the first two replies I got there.
