Do you mean
0
Accepted Solution
BT vision connections
I have had to relocate my computer and now it is no longer practical to run an ethernet cable from my TV and so my BT vision is inactive.  Is ther any way to connect the BT Vision box to my Home Hub wirelessly?
John Gray
Guru
0
Re: BT vision connections
Not that I know of, but you could invest in some Powerlines, or similar, if BT didn't supply them. These effectively turn your electricity main into an ethernet.
Recognised Expert
0
Re-contract your BT Vision and ask them for some new powerlines Smiley Wink
Distinguished Guru
Welcome John,
What you need are powerline adapters which were probably supplied with your original order. You plug one in where the Hub and connect it via a supplied ethernet cable to the home hub.
You then plug the other one in to a spare socket beside your TV and connect the box via and adapter via an ethernet cable and all works provided you aren't using extension leads.
That's the only way to get a BT Vision service working without a direct HUB to Box cable. So it's not wireless per se but it will allow your box to be active.
BTLife | 1967 Plus Radio | 1000 Classical Hits
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Helpful Post?
If a post has been helpful, say thanks by clicking the ratings star.
0
Thanks everyone - yes, Powerline adaptors look like the way forward.  No, I did not get any with my original order - is this something BT will provide, or do I need to go shopping?
John Gray
Recognised Expert
0
BT will provide them if you ask for them...
Just say you were not provided with any when you ordered and if they could send you some.
OR
Recontract your Vision and ask for some Powerline's to be thrown in (you may even get a new black Vision+)...
0
I did not get powerline adapters when I got vision, as the sales person asked me where the vision box and hub where to be located.
I should of said that they where in different rooms as I did not get them, and if I move my TV into the other room i will need to buy them or try and get BT to send them.
let me know how you get on.
Distinguished Guru
John Gray
I think you should phone them up and simply ask for them and explain your situation that they weren't supplied with your original order and now you need them as the set up has changed. It really ought not to be a problem. If it is get back to me and I will suggest al alternative route.
Helpful Post?
Recognised Expert
0
If you have a couple of spare wireless routers there is a way
depending on the routers but if they are capable of running in bridged mode then you can do the following
your home hub is connected as normal ie to phone line and wireless to other computers and optionally via one cable to a PC
the second Ethernet cable is connected to one of your spare wireless routers
this must be configured as follows
first dhcp must be switched off as ip address allocation will be handed by the home hub
second bridged mode should be enabled and the mac address of the second router entered as the bridge
ssid for wireless must be unique ie different from the home hub and any security you want (wpa)set up
the second spare router is configured the same ie no dhcp bridge mode enabled and the mac address of the first router entered as the bridge
an Ethernet cable is then connected from the second router to the bt vision box.
i can not be more specific on setup as all routers differ but i do know that as long as both spare routers can be bridged it will work
for example i have bridged a wireless connection between me and my neighbour allowing his netbook to boot and use a full linux system running on my data server and pxe boot
no trees were harmed in the sending of this message but millions of electrons were terribly inconvenienced
Distinguished Guru
0
whoosh over my head that went Smiley Happy
Helpful Post?
