Do you mean
Newbie
Bt Vision Technika
0081 code works with the remote control for Technika TV.  Was frustrated so entered loads this one worked with mine.
Newbie
0
Re: Bt Vision Technika
Thank you ginnyfly!  I was getting really cross when I couldn't get it to work.  This code worked for me too!
0
Mate thank you so much that code worked on our umc tv.
Even umc said there tv wont work with bt vision untill a new remote comes out.
