Do you mean
Newbie
0
F1 on iPlayer
It appears that for two weeks on the bounce, the F1 isn't working, yet other programmes are. Anyone else having problems?
ta
Distinguished Guru
0
Re: F1 on iPlayer
[ Edited ]
OK here on the internet but there's a problem on BTV.
You can click the white star next to this message if you think it was helpful.
Distinguished Guru
0
Re: F1 on iPlayer
Indeed not working here on the iPlayer on BTVISION
BTLife | 1967 Plus Radio | 1000 Classical Hits
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Helpful Post?
If a post has been helpful, say thanks by clicking the ratings star.
Guru
0
Re: F1 on iPlayer
Sorry:no results message on Bt vision
There has been a problem playing this programme.
Plays Ok on Youview
Distinguished Guru
Re: F1 on iPlayer
Have passed this on for investigation
Helpful Post?
Newbie
0
Re: F1 on iPlayer
Distinguished Guru
0
Re: F1 on iPlayer
It's working this morning. Must be the Hand of Stuart.
