Do you mean
Accepted Solution
Factory Reset
Vision box turned off by mistake during update.
Have tried several factory resets.No joy.
Still going to Red X.
Any suggestions
Cheers Barry
Recognised Expert
Re: Factory Reset
By factory reset did you mean holding the power button for 15 seconds or even removing the power lead for 30 seconds and replacing or a Full Factory reset as described below?
Factory Reset
  • Switch off the Vision+ box at the mains socket
  • Hold down the front panel OK and down arrow buttons
  • Switch on the power to the Vision+ box
  • Allow the box to start up (about 15 seconds)
  • Release the OK and down arrow buttons
  • The Vision+ box will then contact the servers to get a new copy of its firmware
  • This will take around 30 minutes
no trees were harmed in the sending of this message but millions of electrons were terribly inconvenienced
Re: Factory Reset
Yea,
Thats the reset I used.
Gonna try connecting directly to hub.Incase adapters have got confused.
Thx Barry
Re: Factory Reset
No good.
Red Xjust wont go away.
Time for a new box .
Barry
Recognised Expert
Re: Factory Reset
have you rebooted the hub and let it start up first before restarting the vision box.
sometimes helps
Re: Factory Reset
Thx for the help.
Engineer calling on monday.
I can build Pc,s and reinstall any windows.
But this is a cert X.
Not spending anymore time on it.
Let you know how it goes.
Cheers Barry
Re: Factory Reset
Engineer called today new vision box.
Happy Chappy.
Bazz
