Do you mean
0
Factory Reset
Hello,
Just wanted to pick someone's brains about this one! I did a factory reset as I have had enough with any on demand (TV, Music) freezing for 2 or 3 seconds at the start unless I pause it for 3 seconds then press play (might as welll just wait for it to unfreeze itself.
This didnt solve the problem, does anyone else have this? its annoying when you listen to music as you miss 3 seconds of the music and the video everytime you rewind or skip forward! grrrrrrrrrrrrrrrrrrrrrr
Guru
0
Re: Factory Reset
Unfortunately this is an "it does that". I don't know of a fix. Can you rewind to the beginning after the pause?
0
Re: Factory Reset
well if i try and rewind or skip forwar while its frozen i get a v04 error but then it continues playing normally...
Recognised Expert
0
Re: Factory Reset
You can stop it from doing this by pressing pause, wait a few seconds then play again.
It's been doing this for a long time, and it looks like BT have made no attempt to fix the issue.
Distinguished Guru
0
Re: Factory Reset
Hi
V04 errors are normally attributed to speed issues, can you visit www.speedtester.bt.com and post back the results?
(If I have helped you in any way to say "Thank You" please click on the star next to the message. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
0
Re: Factory Reset
Hi Dave,
Ok will do that now and post results, although i have no issues with speed on my laptop when using broadband nor when on bt vision (no stuttering when its actually playing or anything only when rewing/skipping forward or at first play)
0
Re: Factory Reset
Test1 comprises of three tests
1. Best Effort Test: -provides background information.
 Download  Speed
 15756 Kbps
0 Kbps21000 Kbps
Max Achievable Speed
 Download speedachieved during the test was - 15756 Kbps
 For your connection, the acceptable range of speeds is 4000-21000 Kbps.
 Additional Information:
 Your DSL Connection Rate :23549 Kbps(DOWN-STREAM), 1189 Kbps(UP-STREAM)
 IP Profile for your line is - 19000 Kbps
2. Upstream Test: -provides background information.
 Upload Speed
 972 Kbps
0 Kbps1189 Kbps
>Upload speed achieved during the test was - 972 Kbps
 Upstream Rate IP profile on your line is - 1189 Kbps
3. Quality Service Test: -provides background information.
Video Service Quality Test Passed
Recognised Expert
0
Re: Factory Reset
There's nothing wrong with your download speed, it's more than fast enough to support BT Vision Smiley Wink
How about running the test again but play an On Demand title at the same time?
0
Re: Factory Reset
ok will give that a try now
0
Re: Factory Reset
here are the results while playing Father Ted! lol (that still froze at the start)
 Download  Speed
 14457 Kbps
0 Kbps21000 Kbps
 Download speedachieved during the test was - 14457 Kbps
 IP Profile for your line is - 17400 Kbps
2. Assured Rate Test: -provides background information.
 Download Speed
 10904 Kbps
0 Kbps1600 Kbps
 Download speedachieved during the test was - 10904 Kbps
 For your connection, the acceptable range of speeds is 1536-1600 Kbps.
 Assured Rate IP profile on your line is - 1600 Kbps
3. Upstream Test: -provides background information.
 Upload Speed
 928 Kbps
0 Kbps1189 Kbps
>Upload speed achieved during the test was - 928 Kbps
4. Quality Service Test: -provides background information.
