Do you mean
0
Accepted Solution
Finding code to use BT remote to control TV.
Hello,
This is my first post. System installed by me today and works very well. There's a bit in the instructions about controlling my TV using the BT remote. My make of TV, Luxor, is not on the published list. I get no response when trying to use bt.com/help/remote  which has a link titled TV codes. I get a small exclamation mark when clicking these links. Am I doing something wrong? Does any body know the codes for LUXOR?
Thank you for any help.
Andy
Distinguished Guru
Re: Finding code to use BT remote to control TV.
Welcome to the forum. Try these:
You can get the full PDF here.
You can click the white star next to this message if you think it was helpful.
0
Thank you. We must have had the same chain of thought as I googled the problem and the first site came up trumps. I'm still puzzled that the suggested links in the user book didn't work.
Cheers,
Andy
