Do you mean
Hard disk capacity indicator (new system)
On the new system, the Recordings page includes a hard disk capacity indicator in the shape of a blue bar.  However, the bar never appears to move up or down, so I'm wondering if it actually works.  Even when I had zero recordings, it showed some capacity used up (On Demand perhaps?), though I have 20 or so recordings saved now, including a few films, and it still appears to be showing the same capacity.  Has anyone else noticed this as well?
Re: Hard disk capacity indicator (new system)
What capacity box have you got?  I have the 500GB one and it took a lot of recordings to drop the remaining percentage a lot.
I'm not sure to be honest. Is there an easy way of telling? I've had it since mid-March, so assume it's the 160gb version. Mine shows a bar rather than referring to a percentage.
Posted from my mobile
Ah, probably a 160GB one.  I got mine in July and i think i was one of the first
Guru
[ Edited ]
Is that the one that's bigger on the inside than it is on the out?
Recognised Expert
[ Edited ]
I think thats called a TARDIS. Smiley Wink
Rank - Mostly Harmless.
