Do you mean
Newbie
How do I get my BT vision box remote to control volume level?
I have a black BT vision remote which I have set via code to work with my TV. everything works fine except for the volume and mute controls which it has no effect upon.
Re: How do I get my BT vision box remote to control volume level?
Try one of the other codes? Some brands have multiple codes for TV's. Other alternative is to invest in a Logitech multi device remote. You can the programme the remote in an easy to use interface on your computer to control all your devices and also set up quick launch buttons to do things like switch everything on at once etc.
