Do you mean
0
My bt vision box keeps randomly rebooting. Who do I contact to get it fixed?
MY box keeps rebooting. When I contacted BT the Indian gentleman told me to reset the box. However I have read that this does not solve this problem which seems to be common. I have replied that this is the case and asked to speak to senior staff member but got no reply !!!
Recognised Expert
0
Re: My bt vision box keeps randomly rebooting. Who do I contact to get it fixed?
As you say it's a common and known issue, one positive is that it does get better with every new firmware release so hang in there.
0
Thanks for your reply. I will still keep asking bt why this happens not going to reset box as they advise as I have read this does not work.
Guru
0
It can and does help. If you aren't a new customer or tied to Sky Sports a switch to YouView will give you a stable box.
BTLife | 1967 Plus Radio | 1000 Classical Hits
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Helpful Post?
If a post has been helpful, say thanks by clicking the ratings star.
