Do you mean
Community Manager - Retired
NEW: Sports Card Activation via BT Vision box
[ Edited ]
If you have problems with your Sports channels and get an onscreen message saying “Please insert the Viewing Card in the Viewing Card slot” this might be because your viewing card needs activating!
If you’re a sports subscriber and have a viewing card you can now activate your card on your TV.
There are two ways to access Sports Card Activation:
1. Simply press BT Vision on your remote, scroll to Help and choose ‘Sports Card Activation’. If you can’t see this option, reboot your Vision+ box by turning it off and on again at the wall socket, it should then be available.
2. Select Channel 999, then choose Sports and then select ‘Activate your Sports Viewing Card
You can also find more help for your sports subscriptions at http://www.bt.com/help/sports
Retired BTCare Community Manager - StephanieG and SeanD are your new Community Managers
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on the left-hand side of the post.
