Do you mean
0
Accepted Solution
Powerline Adapters not working
hi  i have had no problems with BT Vision untill this afternoon when i noticed the powerline data light went out i've reset both adapters several times but to no avail  is there anything else i can try without calling BT.
Guru
0
Re: Powerline Adapters not working
Is your broadband connection active, and your hub functioning ok?
You could try to reset your hub, and then marry the powerline adaptors again...............
AQ.
"Welcome to Royston Vasey - You'll never leave."
0
yes i've reset the hub and tried to marry the powerline adators again but still nothing
0
Have you tried the standard BT help page?
Resetting Powerline adapters
Guru
0
Is you PC working via an ethernet cable? Is it possible to link BTV box to the hub via a cable?  Has your bbspeed dropped way down?
If it isnt the bband or the hub, IMHO its just the powerline adaptors or one of them are dud.  If you are in contract with BTV, they will replace them and it should be FOC.  Give the helpdesk a ring and they will send out the latest pla's. Dont throw the old ones away, as they'll send a return to us freepost envelope.
AQ.
0
broadband is fine i've told my dad its the adaptors but no doesn't believe me
Guru
0
Well then, I'd get on the phone and ask for a new set before they shut shop for the night.  Proably be here tmrw or day after at the latest.
AQ.
0
PS if the Vision Box is still powered up don't turn it off or it might not start again until you get it back online (standby is fine)
i've been on the phone at teatime to BT Technical Support and they've agreed to send out some replacements
Guru
0
Please let us know hoe you get on.
IMHO, that should be you sorted.
AQ.
