Do you mean
0
Reminder function
Hello All
Does the BT Vision box support some kind of "Reminder" function? like the Sky boxs do (and my TV for that matter) where I can set a reminder to view something on a freeview channel rather than record it?
If so - How?!
JC
0
Re: Reminder function
You can't, the Vision box doesn't have a reminder function.
As been suggested some time on here before, the only closest thing you can do is to set up a recording and when the recording starts a banner appears at the top of the screen telling you the recording has started, you could then use this as your reminder and stop the recording or delete it later.
Newbie
0
Doesnt the recording banner only appear if you're watching that same channel at the time though?
I always have to try and keep an eye out for the red record light coming on!
0
Oh well that answers why I haven't been able to find it because it hasn't got one! DOH!
30 Years Too Late Mate!
