Do you mean
0
Accepted Solution
Vision Box clock not advanced to British Summer Time
Bit of an odd one, this.  Only had BT Vision a week.  Yesterday evening, I noticed that the Vision's time (when I pressed Ok/Select) had not advanced to BST.  Not only that, the TV Guide appeared to be running as per this incorrect time, i.e. programmes that should have finished an hour before were being played.  I also couldn't scroll right after pressing Ok/Select to view later programmes.
I undertook a factory reset and, whilst I can now scroll right to see later programmes, the time is still showing as an hour slow.  The result is that programmes are shown at the correct time, e.g. Postman Pat was on Cbeebies at 7.15am this morning, though on the TV Guide it was showing as being on an hour earlier, at 6.15am.
Supplementary to this is the fact that, whilst the factory resent deleted the couple of recordings I'd made from the memory (which I knew it would), when I go to 'Recordings' the memory bar is showing a bit of blue, as though the memory isn't completely empty, despite there being no recordings now saved.
Has anyone experienced similar or able to assist?
Thanks.
Moderator
Re: Vision Box clock not advanced to British Summer Time
Hi Jackacarlos76,
Welcome to the forum and thanks for posting. We have noticed a problem over the weekend with the time change but we’ll put that right later this week. Don’t worry about any recordings etc. The programme titles and running order are being shown correctly and any recordings you have scheduled will record the right programme.
Cheers
David
DavidM | BT.com Help Site | BT Service Status
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Try a Search
See if someone in the community had the same problem and how they got it resolved.
Make sure you are logged into the forum otherwise you will not see our contact link when a moderator offers help. When sending us your details please don’t send a Private message (PM), we can’t deal with account/service issues via PM so please use the contact link. Thank You
Order tracker survey We would really appreciate it if you would take a few minutes to complete a survey about BT’s order tracker? You can access the survey from this link Order Tracker Survey
0
Thanks, DavidM, for the response.
Don't suppose you're able to shed any light on the fact the 'memory bar' in the 'Recordings' screen shows some blue, suggesting it isn't completely empty, despite me performing a factory reset, thereby deleting the small handful of recordings I had made to date?
Does this memory bar ever show as completely empty or does it sound like I've got something hidden away taking up space, despite me having no saved Recordings?
Thanks.
Guru
The live channel buffer takes up some disk space as would any HD/3D downloads, although I would have thought the latter would be cleared by the factory reset.
