Do you mean
Newbie
audio description
Works fine on freeview but as soon as I change to HDMI 2 and into BT vision I have this continuous audio description dialogue. I have reset HUB and tried default but still left with the problem. Any ideas how this has happened and how do we get rid of the dialogue.
Recognised Expert
Re: audio description
to switch audio description off
btvision - settings - general settings - audio description
scroll across and make sure disabled is ticked and then scrol back and click on save
this should dissable it for you
no trees were harmed in the sending of this message but millions of electrons were terribly inconvenienced
