Do you mean
Newbie
0
Accepted Solution
wireless range homehub2
can anyone help, i am trying to connect my wireless enabled tv to the internet via the homehub 2, the tv is less than 5o feet away but there is a 6 inch brick wall in the way, i have tried a plug in usb signal booster but the signal strength on the tv wasnt strong enough
Distinguished Guru
0
Re: wireless range homehub2
Hi sh123 and welcome
Do you have a wifi enabled laptop?
If so download inSSIDer - http://www.metageek.net/products/inssider/ - and run it next to the TV.
Check the signal strength and also check if any other hubs/routers are also on the same channel.
If there are any, move your wireless channel to a free or less congested channel - done via the hub manager
See if the TV now works....
-+-No longer a forum member-+-
Distinguished Guru
0
I assume you have BT Vision since you have posted this here. If so does your Internet TV have an Ethernet port? If it does then a simple Ethernet splitter will allow you to connect your TV and BT Vision box via the comtrend power adapter
BTLife | 1967 Plus Radio | 1000 Classical Hits
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Helpful Post?
If a post has been helpful, say thanks by clicking the ratings star.
Recognised Expert
0
You could change the wireless interface to 802.11b/g (This should make the connection more stable) with it based on channel 4 or 7 which are usually the least congested ones.
You might find the Hub 3 a good investment at £47 if you want to buy outright or free if you recontract to BT Broadband for 12 months or more, I have the Hub 3 and it has the best wireless range of any router I have used before and it saves all of the hassle of faffing around with channel selection/ transmission speeds as it does it all automatically and monitors 24/7.
Recognised Expert
0
Splitting the ethernet connection is always an option and splitters can be picked up for a few quid at Screwfix.
