Message 1 of 7
700 mins change
Because 700 mins call plane (Landline) is no longer available I have to change to pay as you go…what is the cost of calls on this plan?
6 REPLIES 6
Message 2 of 7
Re: 700 mins change
if you make just a few calls per month you would be better on the unlimited plan £12pm or maybe negotiate a reduction
https://www.bt.com/landline/calling-costs/
Message 3 of 7
Pay as you go
Are any calls included with £3 pay as you go on changeover to digital land line package
Message 4 of 7
Re: Pay as you go
Calls to 0800 numbers (and equivalent ‘free’ numbers ) emergency calls etc , but everything else is charged for , a simple guide is to treat  the outgoing call option on a PAYG option as an absolute last resort , given a 3-4 minute call is around £1…..use a mobile with included minutes as a first choice, if you expect to make more than 45 mins of calls per month , the unlimited option is the better choice , I have PAYG , I can’t remember the last time I used it for an outgoing call , the incoming part , in my case is still worthwhile.
Message 5 of 7
Re: 700 mins change
I would absolutely agree that the unlimited calling plan is worth it if you use the phone even on a semi regular basis as the call costs can mount up fast.  The call plans are not contracted though so if you find later you are not using the phone you can change it around
Message 6 of 7
Re: Pay as you go
I wish the BT person had explained that .thanks
Message 7 of 7
Re: 700 mins change
Better info then the BT operator gave me ..Thanks
