johnjohnston25
Message 1 of 2
Amending address with open reach
Can anyone advise how I get my postcode correct with open reach as it’s causing problems getting connected to bt
1 REPLY 1
-Richie-
Expert
Message 2 of 2
Re: Amending address with open reach
Your current provider will need to raise an ORDI (Openreach Data Integrity), if you don't have a current provider you'll need a line installed first, that should then update the address.
