Message 1 of 17
Cancel broadband and keepn landline
I'm having massive issues trying to cancel broadband and just keep landline number. Did it via BT chat who messed it all up and cancelled everything....have spent a week trying to get that cancellation removed and to start again. Absolute nightmare and BT don't seem to know how to do it.  Anyone else had similar?
16 REPLIES 16
Message 2 of 17
Re: Cancel broadband and keepn landline
Is it that you are trying to transfer the number to another provider, or are you trying to cancel broadband but keep the landline phone?
If the latter, then they are turning off the old "landline" phone system altogether in January, so I don't think just keeping the landline is do-able.  It would need to be upgraded to Digital Voice (DV), which is part of the broadband connection.
If transferring the number to another provider, then I believe the gaining provider has to request that, so you will need to talk to them.
Message 3 of 17
Are you wanting to keep your current BT phone service ( ie Digital Voice) but without their residential broadband service.
Oh, I see @WSH  has responded better.
Message 4 of 17
The current price for a BT phone service on a PAYG basis ( without a broadband service associated with it  ) is £31.20 , the cheapest BT broadband and phone on a PAYG basis is £31.99 so what’s the motivation for you doing this (wanting BT to supply a phone only service) , that’s assuming it isn’t saving a few pence per month  ?
What you require , a new installation of a standalone phone service (not someone who historically already has a standalone phone service )  is no longer a common request , because the financial difference is minimal , and simply put it’s not just a case of disconnecting broadband and leaving a phone service in place , you would need to cancel your complete broadband and phone service as it is and then reorder as a phone only service ( that’s assuming you can an order for it raised given it’s an uncommon request that can’t be done online you need to call  ) .
A new standalone phone service is problematic in its own right because you are not an existing phone only customer, so don’t qualify for a PDPL , that’s the way existing phone only customers are converted from PSTN onto a system than will last after Jan 2027 when PSTN telephony is switched off, it isn’t available to you as it’s for existing phone only customers not new ones .
The only other post on here I can recall, with a similar requirement to yours  ( a new phone service without a linked broadband) was the customer was provided with BT broadband and DV (Digital Voice telephone) the broadband supplied without charge , but conditional on it never being used apart from hosting the DV telephone service , should the customer connect anything at all to the ‘internet’ either WiFi or wired Ethernet, then BT would start charging for the previously free broadband because the customer was clearly using it for ‘the internet’, if they only used DV and stringently never connected anything but a standard telephone (corded or DECT ) then broadband remained free.
..if you want this type of arrangement, good luck trying to arrange it , personally I’d think it not worth the hassle to save 70p a month .
Message 5 of 17
According to BT the price for landline will be £12 approx. You don't have to be so sarcy in your answer thank you.
Message 6 of 17
Where do you get £12 a month from ?
https://www.bt.com/landline/deals
Message 7 of 17
Also the issue is with BT not doing as requested regardless of the reasons for it.
Message 8 of 17
They told me this on the phone and in online chat. Probably lying to me as with everything else so far.
Message 9 of 17
It's just DV that I've requested to keep. This can be done..."regrade to home phone only" apparently
Message 10 of 17
I believe it can but it still needs a very basic broadband connection, as iniltous mentioned.
