Impgreene
Message 1 of 5
Change BT Forum login name (username)​
It appears from other threads that I can't change this without contacting a Moderator, but there is no mechanism to contact a Moderator.
Please can someone send me a method of contacting a moderator.
Thanks.
4 REPLIES 4
Moderator
Moderator
Message 2 of 5
Re: Change BT Forum login name (username)​
@Impgreene You can PM me with your suggestion and I'll be happy to help you get this sorted.
Moderator
Moderator
Message 3 of 5
@Impgreene I'm am not going to be on the community again for a couple of days but you will be able to PM the moderator on duty to request this.
SpikeOnabike
Message 4 of 5
Hello I'd like to change my login (user name) - can you please advise how to arrange this?
Moderator
Moderator
Message 5 of 5
Hi @SpikeOnabike,
I'll be able to arrange this for you. If you drop me a PM with your suggestion I'll be able to change the username for you.
PaddyB
