Anonymous
Not applicable
Message 1 of 15
Closing BT community account
I havent used BT for years and would like to close by old BT community account. How on earth are you suppose to do this???
Tags (2)
14 REPLIES 14
Message 2 of 15
Re: Closing BT community account
You can't, only the mods can. I will ask them to intervene.
Moderator
Moderator
Message 3 of 15
Hi @Anonymous I've sent you a PM please can you check it and reply back to me.
https://community.bt.com/t5/notes/privatenotespage
Cheers
John
Community ModeratorJohnC
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
Anonymous
Not applicable
Message 4 of 15
Ok, thanks for your help.
Seems odd that users can't do so themselves though?
Moderator
Moderator
Message 5 of 15
You are very welcome @Anonymous.
We'll get it closed for you and remove any personal identifiable information.
DanielS
Community ModeratorDannyS
Kudos”
Distinguished Guru
Message 6 of 15
DanielS
You really need to investigate why users can't instigate this themselves. You seemed to have ignored the issue. The GDPR has a section called right to be forgotten. I suggest this is looked at.
Message 7 of 15
DanielS
Where in the GDPR does it state that the person has to be able to remove the data them self. As far as I can see it only makes a requirement to have the data removed by the data holder if the person requests it or it is outdated and no longer relevant.
Distinguished Guru
Distinguished Guru
Message 8 of 15
What exactly is self-closure of accounts envisaged to mean in practice?
The GDPR clearly require that defined personal information is removed on request, and DanielS has covered it, though there's precious little attributable data in the body of this forum. What is expected beyond that? Surely not the removal of all contributions made by an individual, which would in many cases render legitimately recorded discussions unintelligible.
Message 9 of 15
It means that any identifiable data regarding the person should, in certain circumstances be removed if requested. Therefore any contributions, unless it contained identifiable information, could remain.
Distinguished Guru
Distinguished Guru
Message 10 of 15
I understand and go along with that. What I meant was how those advocating self-closure would expect it to work.
