Do you mean
How do I mark a post as a question?
Is this a question?
Value Added Guest (Inspiring Not Aspiring)
Rate a post if you like it! - just click the star under the user's name on the left. (N.B. ratings facility no longer available in Forum Help and Suggestions; nor is it available in the Lounge)
Re: How do I mark a post as a question?
I don't think you can.  You can however mark subsequent replies as "solved" using the options menu on the relevant post.
Cheers
Alun
"Can a leopard change it's shorts?" - T Prattchet
Ah, that's a relief Alan, thank you. I was going nuts last night vainly seeking the method, because I was sure I'd seen Dorset somewhere refer to marking a new thread as a question at the point of formulating it.
[ Edited ]
It looks like we can be sure of this Alun because nobody's come forward to say otherwise. I'll now mark this qestion as answered Smiley Happy
However I note that nobody has answered the question I posted in the body of my original post: "Is this a question?" Smiley Wink
Moderator
Hi Guys
I think AlunH hit the nail on the head there. post your question as you would in any post and then pick the best solution, that way anyone else reading the thread can jump to the solution straight away.
Cheers
Stuart
StuartH | BT.com Help Site | BT Service Status
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Try a Search
See if someone in the community had the same problem and how they got it resolved.
Make sure you are logged into the forum otherwise you will not see our contact link when a moderator offers help. When sending us your details please don’t send a Private message (PM), we can’t deal with account/service issues via PM so please use the contact link. Thank You
Order tracker survey We would really appreciate it if you would take a few minutes to complete a survey about BT’s order tracker? You can access the survey from this link Order Tracker Survey
Surely if you open a POST with the standard question word and end it with the expected ?, this should suffice to satisfy you requirements.
Have this Windows Home Premium 7 and really need to be able to print out messages so they can be read - even Sherlock Homes with his magnifier would't be able to read it!
I thought the way to mark a question as solved was for the original poster to click the radio button "mark as solved" that appears below the "reply" and "quick reply" radio buttons?
wedding
Mistakes and embarrasing goofs in e-mails are only discovered when you've sent them!
Happy, I'm not sure what you are aiming at here, or did I miss something?
wedding
