Message 1 of 4
IMG 9837
How do i view a IMG 9837 some one has sent me?
3 REPLIES 3
Message 2 of 4
Re: IMG 9837
Do you know the person who sent you the file and do you trust the contents of the file.It could be a virus or malware and if you are not sure why you received it I would just delete it.
An IMG file is a file that can be a disc image file containing the entire contents of an entire disc. ie a copy of an operating system or similar.
It could also be an image file that is used by some camera systems.
As this is not a BT problem I would suggest that you do an Internet search on "what is an IMG file and you will find plenty information about what it is and how to open it.
Message 3 of 4
Re: IMG 9837
Hello,  yes it is someone i know and trust, and it is a Vidio but i do not know how to open it>
Message 4 of 4
Re: IMG 9837
as @gg30340  suggested just search using google or edge and there a numerous suggestions on how to open/view an img file
