WilfH
Message 1 of 4
IOS - can’t see message icon
Hi
When using the forum on iOS I do not see the message icon even though I’m logged in. I do see it on ordinary desktop browsers. I’s this a ‘feature’ of the mobile version of this site?
WilfH
3 REPLIES 3
Allyson2
Newbie
Message 2 of 4
Re: IOS - can’t see message icon
yeah, that is just the part of the mobile version of this website, I think that's normal when you open the website on mobile browser.
https://ios13guide.com/
Distinguished Guru
Distinguished Guru
Message 3 of 4
Android has a facility to choose the desktop site where appropriate; you can then add it to your home screen (effectively a bookmark) to give direct access subsequently. Hopefully, an iPhone aficionado will advise if something similar is available.
WilfH
Message 4 of 4
IOS does indeed have this facility however if the requested site detects the requesting clients browser string as being WebKit based it will always redirect to the mobile of the site effectively defeating this facility.
Wilf
