Message 1 of 6
McAfee LiveSafe Premium Plus vs BT Virus Protect by Norton
What are the differences in security features between McAfee LiveSafe Premium Plus and BT Virus Protect by Norton and whether BT Virus Protect supported by Norton falls under Norton 360 Standard, Deluxe, or Advanced? The links are shown below:
https://www.mcafee.com/en-gb/antivirus/mcafee-livesafe.html
https://uk.norton.com/products/norton-360-standard
https://uk.norton.com/products/norton-360-deluxe
https://uk.norton.com/products/norton-360-advanced
5 REPLIES 5
Message 2 of 6
Re: McAfee LiveSafe Premium Plus vs BT Virus Protect by Norton
@BasDav-1wrote:
What are the differences in security features between McAfee LiveSafe Premium Plus and BT Virus Protect by Norton and whether BT Virus Protect supported by Norton falls under Norton 360 Standard, Deluxe, or Advanced ?
BT Virus Protect by Norton. Free, what's not to like. All-In-1's & Av's are at best, as good as the sites you access.
BE SAFE OUT THERE !BE SAFE OUT THERE !
Message 3 of 6
BT Virus Protect may be free but what are the differences in security features against those of Norton 360 Standard, Deluxe, and Advanced? The features of BT Virus Protect need to be clearly explained.
Message 4 of 6
Or is BT Virus Protect by Norton based on Norton Antivirus Plus?  The link is shown below:
https://uk.norton.com/products/norton-360-antivirus-plus
Message 5 of 6
BT Virus Protect is powered by Norton and primarily focuses on protecting devices from harmful viruses and online threats, while Norton 360 offers a more comprehensive suite that includes antivirus protection, identity theft protection, VPN, and additional features like cloud backup and parental controls. In comparison, Norton 360 Standard, Deluxe, and Advanced provide varying levels of cloud storage and identity protection services, with Advanced offering the most extensive features
Feature BT Virus Protect Norton 360 Standard Norton 360 Deluxe Norton 360 Advanced
Antivirus ProtectionYesYesYesYes
Identity Theft ProtectionNoLimitedYesExtensive
VPNNoYesYesYes
Cloud BackupNo2 GB50 GB200 GB
Parental ControlsNoNoYesYes
Dark Web MonitoringNoNoYesYes
Social Media MonitoringNoNoNoYes
Message 6 of 6
@Paul862  Just so you are aware, you’ve responded to a thread last contributed to, 2 years ago 🤷‍♂️
