gng098
Newbie
Message 1 of 2
Possible Scam
Yesterday, the phone rang and the caller claimed to be from BT. He stated that I had been overcharged by a considerable amount for my line rental. He sounded genuine and said that calls might be recorded for training purposes etc. However, he then asked for my first name, which I thought a bit odd, and then for my date of birth. I then asked why he wanted that and he said it was for their records. Howerver, I didn't give it and , suspecting a scam, ended the call.
1 REPLY 1
Moderator
Moderator
Message 2 of 2
Re: Possible Scam
Hi @gng098 and welcome.
You're quite correct in ending the call. It's most definitely a scam call.
Cheers
David
Community ModeratorDaveM
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
